Ah, I see, so dbtech is using the default editor?
I like the dark background :/ blends much better with my template.
Looks like I'll have to live with it then.
No not in vb versions with the ckeditor, those editor controls are different. You can test it on your site by re naming the bold.png to bold1.png and load the image I posted to the folder and see the changes. If you don't like it you can then delete the bold.png you loaded, then rename the bold1.png to bold.png
