Unfortunately we cannot guarantee compatibility with 3rd party modifications. APTL hide function is compatible with every system that uses normal vBulletin BBCode parsing, so this is nothing we're able to fix.
PS: For future reference, "Product Version" means your APTL version, not forum version :)
Using this mod:
http://www.vbulletin.org/forum/showthread.php?t=232993&highlight=modification
links are not hidden... i only see the bbcode but nothing is hidden.
please fix this, hide should work on any forum place because is a all forum functionality
Fillip H. will have a look at it, however we can't guarantee compatibility with mods - it would take us much too long to go around finding ways to change things to make them compatible with individual modifications.
Cosmic
BTW I notice that mod the Ordered List, Unordered List, Decrease Indent, and Increase Indent also do not work, so it is that mod that has the issue not APTL
The mod is basically unsupported as the Dev for it has not fixed any bugs on it for awhile, and again DBT does not guarantee compatibility with mods
yes!, the mod is unsupported but it still using default vbulletin editor...and dragonbyte thanks mod works on it..
so whats the problem?
For the record the default editor and the default method for parsing BBCode are not necessarily the same thing - we simply don't have the time to try that mod and find out why it breaks APTL, then try to repair it.
Cosmic
