the-danzor
Please send me a link to your website so i can check that last issue out. The out-dated templates will be fixed in Fridays update.
Edit the Links next to the social icons, replace the "#" with your desired link. You have edited the social network icons so i assume you know where they are. If not please read the Welcome Message as it now acts as a readme :)
Regards,
Scott
the-danzor
From what i can see you have installed the theme incorrectly, the imageset is not found, you have either renamed the folder without changing the classes or uploaded the images into the wrong directory.
Default path:
/styles/DBT_MMO/custom/
Apart from the out-dated templates which do not seem to be modified (you can merge them) there are no issues here, the RED template files are the ones that have been modified and not default template files.
I have however found other issues which are being patched currently, i will also try to get the Custom Images to be changeable by the AdminCP. Allowing users to update the path only once.
Regards,
Scott
