Bug Using a post template will insert HTML code and make the template system unuseable
jluerken
Hi Developers,
adding and editing a post template works like it should but as soon as I want to use it it is full of HTML code.
I've checked your forum and have seen that I am not the only one with this issue.
I tried the solutions in the other tickets but that does not work for me.
I removed /clientscript/ckeplugins/PostTemplates/plugin.js and uploaded plugin.alt.js as plugin.js but still I see HTML code in the template :-(
Also disabled plugin "Integrate Into vB Editor" - "editor_toolbar_end" but no chance.
How can I get rid of the HTML code? vBulletin 4.2
Kind regards
jluerken
This has been answered at vBulletin.org - if the alternate JS file does not fix it for you, then it cannot be fixed. Sorry :(
Hi Fillip H., we just bought the brand free option of this addon because we really wanna use it.
Is there a way that you can check this on our site? There must be something causing this so "it cannot be fixed" cannot be the answer ;)
I've been unable to find a solution for this issue, sorry :(
Unfortunately it looks like I won't be able to fix it for you.
That's really bad news.
Can you give a hint where do you think the problem is so that I can take a look myself?
I believe it's somewhere within CKEditor, it seems to do a BBCode to HTML transformation somewhere, before I insert it into the editor.
I changed .js file and that's worked for me, thanks!
Now all templates are pasting in bb-codes, not in htlm.
Legacy Post Templates
