webi
Recently, no longer appears in our UCP who has a sent a message.
What setting needs to be corrected here?
Regards
vB Optimized been installed.
Whether the error exists for some time and it's just not noticed, unfortunately, can also be.
I'm unable to replicate this issue on your site. Can you please PM me with the access details of an account that is affected by this issue?
All accounts are as far as I could determine affected.
I have sent you the access of my test account.
Here's a screenshot from the test account you've provided me: https://www.dropbox.com/s/ka7kprsn4rltdt3/Screenshot 2014-04-19 20.02.25.png
You are there in the Inbox.
The fault is in the User Control Panel.
Screenshot of the same PN in the User Control Panel.
Could there be another plugin that only runs for you?
No idea what it could be.
Have you tried logging in with this account?
Yes, because it's my test account to check whether errors exist even with normal users.
What browser are you using?
IE11, FF28 & Google Chrome 34
Ah, I can confirm this on your site but not on DBTech. I will post back when I have more information or a solution available.
Update: I've turned off the offending setting (HTML Markup) as I've not been able to make it work in the UserCP preview.
The {vb:raw row.musername} variable in dbtech_vbsuper_pm_view_* is still not defined after parsing pm_messagelistbit from usercp.php
I have to turn off HTML Markup by the same reason :(
Yes, that feature was apparently not tested as it will not work. I will remove it from a future version.
Legacy vBSuper PM's
