RigelBetelguise
Everything seems to work as expected when updating my events from the past to add to the custom currency we are using. But the points never change. I've done the maintence part where it processes the transactions but no change is made to the points collected.
Any ideas?
Do users still earn going forward, according to your settings?
No they actually do not. I've double checked and the mod is enabled in the settings. If you go to the credits.php it shows transactions being made but nothing is happening to their point totals.
Do you get errors/blank pages when trying to update user transactions?
No everything works as expected to.
Have a look at this to make sure you are using that tool correctly: http://www.dragonbyte-tech.com/f62/recalculating-credits-1599/
I did use this with different variations and the same result occurs.
If you'd like I can give you a test account to take a closer look at our settings.
Is that custom currency one that you keyed in yourself, or was it provided by another addon that you have installed?
I've gone ahead and uninstalled the mod and reinstalled it. I've made progress now and it appears to work, I dunno what the issue was, only thing I can think of some error that i missed on the install.
Legacy vBCredits II Deluxe
