That usually means your APC is running out of memory.
If you add this plugin to admin_index_main3
$cache_user = apc_cache_info('user', 1);
$cache = apc_cache_info('opcode', 1);
$stats = array(
    'Variable Cache' => array(
        'Cached Variables'                 => vb_number_format($cache_user['num_entries']) . ' (' . vb_number_format($cache_user['mem_size'], 2, true) . ')',
        'Hits'                             => vb_number_format($cache_user['num_hits']),
        'Misses'                         => vb_number_format($cache_user['num_misses']),
        'Request Rate (hits, misses)'    => vb_number_format((($cache_user['num_hits'] + $cache_user['num_misses']) / (TIMENOW - $cache_user['start_time']))) . ' cache requests/second',
        'Hit Rate'                         => vb_number_format((($cache_user['num_hits']) / (TIMENOW - $cache_user['start_time']))) . ' cache requests/second',
        'Miss Rate'                     => vb_number_format((($cache_user['num_misses']) / (TIMENOW - $cache_user['start_time']))) . ' cache requests/second',
        'Insert Rate'                     => vb_number_format((($cache_user['num_inserts']) / (TIMENOW - $cache_user['start_time']))) . ' cache requests/second',
        'Cache full count'                 => vb_number_format($cache_user['expunges'])
    'File Cache' => array(
        'Cached Files'                     => vb_number_format($cache['num_entries']) . ' (' . vb_number_format($cache['mem_size'], 2, true) . ')',
        'Hits'                             => vb_number_format($cache['num_hits']),
        'Misses'                         => vb_number_format($cache['num_misses']),
        'Request Rate (hits, misses)'    => vb_number_format((($cache['num_hits'] + $cache['num_misses']) / (TIMENOW - $cache['start_time']))) . ' cache requests/second',
        'Hit Rate'                         => vb_number_format((($cache['num_hits']) / (TIMENOW - $cache['start_time']))) . ' cache requests/second',
        'Miss Rate'                     => vb_number_format((($cache['num_misses']) / (TIMENOW - $cache['start_time']))) . ' cache requests/second',
        'Insert Rate'                     => vb_number_format((($cache['num_inserts']) / (TIMENOW - $cache['start_time']))) . ' cache requests/second',
        'Cache full count'                 => vb_number_format($cache['expunges'])
print_table_start();
print_table_header('APC Cache Info', 2);
foreach ($stats as $title => $info)
    print_description_row($title, false, 2, 'optiontitle');
    foreach ($info as $key => $val)
        print_cells_row(array("<strong>$key</strong>", $val), 0, 0, -5, 'top', 0, 1);
print_table_footer(2, '', '', false);
You can see if that's the case.
My apologies for the late reply. I am having serious issues connecting here.
This is what it shows:
Still have the same issues though. Thanks!
In that case you'll need to contact your host with a variation of the message I posted previously - vBO doesn't control how APC responds to cache requests.
I suspect you'd receive similar issues by refreshing the "test2.php" file in that at some point it'll stop reporting "Working!" until you flush the cache again.
