Question Need some help block bar
IcEWoLF
Hi there, how do I remove the red bar on top?
It was not use to be there before, not sure if something changed in the recent versions with the styling.
Looks like that is controlled by the stylevar sidebar_background in the group Sidebar.
Changing that may also change the background on your sideblocks, so you may want to edit the templates dbtech_vbslider_cms.css and dbtech_vbslider_forum.css and change:
.slider_widget .block {
	_margin-bottom:4px;
	padding:{vb:stylevar vbcms_widget_block_padding};
	background:transparent {vb:stylevar sidebar_background.backgroundImage} {vb:stylevar sidebar_background.backgroundRepeat} {vb:stylevar sidebar_background.backgroundPositionX}{vb:stylevar sidebar_background.backgroundPositionUnits} {vb:stylevar sidebar_background.backgroundPositionY}{vb:stylevar sidebar_background.backgroundPositionUnits};
	-moz-border-radius-top{vb:stylevar left}:{vb:stylevar border_radius};
	-moz-border-radius-top{vb:stylevar right}:{vb:stylevar border_radius};
	-webkit-border-top-{vb:stylevar left}-radius: {vb:stylevar border_radius};
	-webkit-border-top-{vb:stylevar right}-radius: {vb:stylevar border_radius};
To this:
	_margin-bottom:4px;
	background:transparent;
And see if that gives you the desired affect.
Legacy vBSlider
