Morrus
I'm having a bit of an installation issue. After selecting the XML file in the product manager and hitting "Import", it whirs away for 30 seconds or so before displaying a blank white screen (image attached).
Tried is again, with allowed overwrite set to yes. It gets a bit further, but stalls:
Importing Product, Please Wait...
Updating Version Number To: 1.0.0
Created Table: dbtech_vbshop_category
Created Table: dbtech_vbshop_purchase
Created Table: dbtech_vbshop_gift
Created Table: dbtech_vbshop_item
Altered Table: administrator
Altered Table: user
After altering the user table it'll move on to the usergroup table, that shouldn't trigger a timeout unless your MySQL server has an issue.
Can you try adding
ini_set('display_errors', true);
just beneath <?php in the config.php file? That should at least show the error message.
Legacy vBShop
