Question VbShop install issues
Website
http://www.role-player.net
Product version
3.5.3
Forum version
vBulletin 4.2.x
#1
Hi there!
I'm attempting to install Vbshop for my forum, however I'm running into some issues.
I have double-checked all files have been uploaded to the correct place in the server. While it all looks like it should be working, when I try to access the settings in the ACP I'm just getting a 'file not found' error on every option. To clarify, I can access settings>options>vbshop settings (all those listed here) The issue is with the DBTech > VBShop dropdown with 'Manage currencies' etc. None of these are working.
I assume the problem is on my end, as I haven't seen anyone else mention this issue. Can you offer any guidance on what I've done wrong?
TIA
Belazor
Staff member
Owner
Developer
Hi there,
If you are receiving a 404 every time you access vbshop.php in your AdminCP, that may indicate that your AdminCP directory has been renamed, and the admincp folder inside the vBShop upload was not renamed before being uploaded to the server.
Can you double-check that and let me know? :)
Belazor
Staff member
Owner
Developer
Company Information
Staff member
Company Info
#5
Hello Guinevere,
vBShop
