How would I go about manually uninstalling? seemed to work for a few min after install and then white pages for admincp and main forum. Only change that was made was installing this mod. I have added the define('DISABLE_HOOKS', true); to config.php with no change.
I ended up just reuploading Vbulletin files and then uninstalling it after files uploaded. Is this not working for 5.1.2 p3? This is a fresh install of VB with just a style installed.
We do indeed, but please do be aware that our ability to create modifications for vB5 is naturally limited by the limitations on that platform. Additionally, the cost is going to be higher due to the fact that vB5 mods require several orders of magnitude more maintenance than vB3/vB4 mods do.
