Bug Error during installation. Now I can't log on ACP!
Website
http://www.gtitalia.it
Product version
1.0.5
Forum version
vBulletin 4.2.x
#1
during the installation of the mod has appeared this error:
Warning: Non-static method POSTBITTABS_CACHE::init() should not be called statically, assuming $this from incompatible context in ..../dbtech/postbittabs/hooks/global_start.php on line 14
Now the forum is hard to see and I'm unable to login to the Admin Control Panel! How can I remove completely this mod?
Default Skin or Custom skin, the same problem.
Help please! Thank!
Thank you Belazor for help me in the holidays :)
I re-download and re-upload all files but I have the same error and ACP not is accessible.
(if you want I can give you in PM details for accessing ftp and db)
EDIT: oohohohohoh !!! :D :D :D I refresh many times, now the error is gone! Thanks you Belazorrr !!! Now I have to fix the double information in the postbit but for this I have the help files... Thank you again!
Belazor
Staff member
Owner
Developer
No problem, glad it works for you :)
If you're using a cache system like CloudFlare, purging its cache after each time you make changes to your forum (or fix errors) will ensure they show up ASAP :)
Postbit Tabs
