Bug Could not find dbtech_postbittabs_view
Website
http://travelblogsuccess.com/forum/
Product version
1.0.5
Forum version
vBulletin 4.2.x
skylab
Not sure what's happening here but there's a series of issues.
I can't edit the Google+ entry. If I click on EDIT, it brings me to the screen shot below as if I'm creating a new entry. Now if I add or change anything, it creates another entry on the top. If I try to delete the top entry or the Google+ entry, it tells me Could not find dbtech_postbittabs_view with viewid = Google.
Screen Shot 2013-01-28 at 4.01.30 PM.png Screen Shot 2013-01-28 at 4.00.23 PM.png
skylab
PHP Version 5.2.9.
I'm on HostGator.
I do not think that's the issue though. The issue seemed to have been triggered shortly after Google+. Could it have been the + character?
Belazor
Staff member
Owner
Developer
Update: The View ID should only be A-Z / 0-9. Can you please delete and remake the view without the symbol?
skylab
I've tried to but it won't let me. Tells me "Could not find dbtech_postbittabs_view with viewid = Google"
I can't delete the Google+ entry nor the default entry called view.
Thanks for the help with this.
Belazor
Staff member
Owner
Developer
I added a workaround, if you re-download and re-upload /dbtech/postbittabs/actions/admin/view.php it should work for you now :)
skylab
That seems to have resolved the issue. Thanks!
New issue now. Since this started happening, it appears nothing past the second tab wants to get viewed. I've tried creating new tabs and deleting others. Even switched them around. Everything past the second tab shows nothing under its actual tab on the forums.
Belazor
Staff member
Owner
Developer
That's most likely related to the non-AZ character in the view name. Now that you can edit/delete, can you try removing and re-creating the view now?
Belazor
Staff member
Owner
Developer
I tried to check this issue out over on your forum but your forum list is blank, and it appears to be impossible to register through normal means.
Can you please create an account for me so I can see this issue in action?
Belazor
Staff member
Owner
Developer
I see 3 tabs; Blog, Social Media, Community.
Community is currently empty, as if it has no views or no views to which my account has permission to view without the tab itself also having similar permission restrictions.
Is that the issue you're experiencing?
In other words, is there supposed to be visible views in the Community tab?
If so, could you please update my account to admin and also PM me with an FTP account so that I can look into this? Thanks :)
skylab
Sorry about the delay. I just set you up as admin. Let me know if you need more permissions.
Yes, community should be showing items. Nothing past the 2nd tab wants to be displayed.
Belazor
Staff member
Owner
Developer
All your Community tabs except for Twitter had malformed HTML, the </a> was lacking the closing > tag :)
I fixed it, and it works fine now :)
Postbit Tabs
