Jeremy
Is there a limit on the amount of times a user can earn credits from a charge tag or something?
If I try to post one it says " You have exceeded the frequency for charging for content per post"
I have both of these fields blank for the Content action:
Maximum Times - After this event has occured this many times, the action will occur without triggering the event again. Use blank for no maximum.
Limit Period - Timespan in seconds that the above maximum is enforced. Use blank for all time.
The maximum number of charge tags per post is a usergroup permission. The maximum amount charged per tag, or the most number of times it can be charged, is part of the event.
Actually, I think this might be a bug.
I removed my self from additional usergroups, and I was able to do it again.
Both my primary usergroup and my additional usergroup had Charged Content set at 1.
The how do I was answered and then marked as answered.
Generally we ask that if you have a bug to report you start a new issue as a bug - otherwise what happened here happens and it slips through the cracks =P
Darkwaltz4 has been alerted to the presence of the thread though and should be along to answer soon.
Cosmic
To clarify, again, the maximum usergroup permission is the maximum number of times you can use the charge bbcode tag within a single post (not "ever").
A value of 1 means you can use one charge tag in each post. Having different numbers across your usergroups = the highest one wins. Is this what is happening?
I tried it where an additional usergroup had it set at 0. It wouldn't let me do it even though, the primary usergroup was set at 1. So the higher number didn't win in that case.
Legacy vBCredits II Deluxe
