Trekkan
Make the "Bookmark Thread" button smaller and fit in better with the forum.
On the userCP page, change the display to the following:
A dropdown for "All", "Threads", "Posts" for viewing instead of the separate links in the left nav.
Add in support for sorting (a nice to have, so I'm putting it here, but nothing major)
Group the results by forum category and forum, then sort threads by date DESC (assuming the above sorting option isn't added).
Display the last post date for the thread/post as well as who posted it, depending on whether you've tagged the thread (display OP) or post, the poster.
Add AdminCP option to auto add to subnav links.
Add in usergroup support for who can use the feature
Add in usergroup support for how many bookmarks each usergroup can have.
Checkboxes next to the threads/posts displayed for mass changes such as deletions.
Would be good to have the "Bookmark Thread" button also be optional and also be able to move it under "Thread Tools"
Ummm, I think that's all I can think of for now. This rocks BTW and thanks for making it. =)
The bookmark thread button is the exact same as the reply to thread button, how does that not fit with the forum :p
Sorry, poor choice of words. More that it sitting where it is stacked on top of the reply button creates a dead space void to the right and it doesn't "fit in" where it is. To the right of "Reply to thread" would be better.
Thank you very much for this hack! It's VERY usefull!
Sort - I mean to have ability make some different folders (as for subscriptions) and sort bookmarks. And also - ability to rename bookmark (user could have some bookmarks in one thread) or to add notes (if renaming is not possible)
+1!
Thanks a lot!
1 Problem and 1 suggestion
First of all, I'd like to thank author for this very useful mod!
I've installed it at 4.1.14 and discovered: "Bookmark Thread" button does present and works, but "Bookmark Post" doesn't. Check it, please. Perhaps I've made mistake.
Further improvement: will You please add "Bookmark Thread" to drop-down thread menu ("Thread options") after "Subscribe to this thread" instead of special button. Just like in vBFavorites mod for 3.x ?
Please do not bump old threads with separate issues, this post will be lost when we're reviewing the next bugfix / feature update :)
I'll look into it soon though :)
Fully support these ideas!
heh +1
Was just about to post up pretty much all of these suggestions.
May I ask if they have been considered? specifically these
Aswell as grouping may i suggest the forum name is placed beside the therad/post name?
I love this Mod btw, its one of the most usefull i have come across and many users on my site have asked for the ability to bookmark key threads, good work.
heh +1
There hasn't been a feature update for this mod yet - generally free mods such as this have a very low priority for updates.
Legacy Thread / Post Bookmarking
