If you disable those features, yes :)
It's calculated using the current daily average points based on your threshold.
Re; Where do i disable them? Thanks.
Say that your threshold is 10 points, and a total of 10 people have earned a total of 100 points. Your average points will be 10. Someone who has earned 10 points this month will be at 100% activity. 20 points = 200%. 5 points = 50%.
vBActivity will automatically suggest a recommended target based on the past week of activity
All i have is a 0 in the box, how long does it take to recommend a target?
Thanks.
I'm not sure what you mean - going for instance to Achievement Settings and turning off Achievements will remove all references to Achievements in the front-end :)
Its a pretty simple question, what option do i change to remove these links from the activity page sidebar.
Activity Contests
Activity Target Winners
That's not what you asked originally though :)
To remove those links you need to edit them out of the dbtech_vbactivity template.
Legacy vBActivity & Awards
