From the screenshot it looks like you are not using the default sideblock widths vBulletin set. go to stylevars and under the group Sidebar, find the setting forum_sidebar_width and ensure that is set to 270 px.
You're correct regarding the 270 px setting. I changed it. Deleted my cookies in IE and it still does the same.
Matt Olieman
MyCockpit.org
PS: I can set up an account for you at MyCockpit.org if you like. Any help is appreciated :)
Did you flush any caching systems you are using like vBOptimize after making the changes?
Does it happen like that on a unmodified default style?
Is your skin really designed to have all that blank space on the right side of the pages?
As you can see in the attached, I don't have a problem with other blocks.
When the page loads, the block momentarily loads in the correct place and then reverts to where it shows in the attached image.
Matt Olieman
MyCockpit.org
Could you please create and PM me with a temporary FTP and AdminCP account? I will take a look at it when I get home from work today.
OK I got it showing ok now, the issue was the block title was to long and was overflowing, breaking the layout due to the width of the sideblocks. The phrase I changed was, dbtech_vbdonate_latest_dons I changed it from Latest Contributions to Latest Contribs.
You may also want to go to the settings, DragonByte Tech: vBDonate - SideBlock Settings and change the setting Name Of The Non Verified Image (instructions can be found in that setting) to a different image as the default image is to big for the block.
There is something wrong with that skin TBH, all the stylevars I tried changing to adjust the width of the sideblocks, or the document width did nothing, which is not right.
So you can disable the admin account and ftp info I am finished there. :)
FANTASTIC!!!! Thank you very much.
As you've probably already noticed vBDonate has already paid for itself. :) All within the past 48 hours.
Thanks again....
Matt Olieman
MyCockpit.org
That's cool, TBH I did not even look, I was to busy trying to find a work around to get the block to work right for you. Glad you are happy with it. :D
Legacy vBDonate
