Nelson
When I try installing, I get:
vBulletin Message
Sorry, you don't have permission to access the administrative controls on this page.
If you need to access this page, ask your lead administrator to enable your permissions for this page using the Administrator Permissions section of the control panel.
Powered by vBulletin® Version 4.2.2 Copyright © 2014 vBulletin Solutions, Inc. All rights reserved.
then when I hit "Go Back", it says:
vBulletin Message
Help please?
You need to add yourself to Super Administrator in config.php then uninstall & reinstall the mod :)
Update:
I fixed the above problem by installing on an account that is PRIMARY administrator. However, when I go to edit USERGROUP settings, half the settings are MISSING. I get:
DragonByte Tech: vBShop - General Permissions
Is Shop Manager
This controls whether this usergroup can access vBShop via the ModCP (if they have access to the ModCP) and whether they can perform other management actions.
Yes No
Can View Shop
Yes No
Can View Bank
Yes No
I do NOT get the first two settings that are supposed to be in the box (Can Create Custom Shop and Deny By Default):
I have tried uninstalling and reinstalling the mod and I still do not get all the shop settings in the usergroups.
Did what you said....still no joy...
I did this three times- still not getting ALL 5 options in the usergroups. Before I buy this, can you please help me clear this up?
Thanks.
Legacy vBShop
