neilbla
Installed this great shout and found all the setting and permission and set the permission so certain groups can carry out a prune of the shouts. The problem i have is how does one carry out the prune of the shouts. Where is the menu to do this.
Thanks for any help you can give.
just type the command /prune or /prune username to prune the shoutbox if i'm correct in thinking.
/Prune - Prunes the entire shoutbox of all system messages and shouts
/Prune username - prunes only the selected usernames shouts for example /Prune neo_Angelo will prune all shouts i've made.
That is correct =)
You can click the small arrow at the bottom left of the shoutbox to see a full list of commands =)
Hey thanks for all the replies. Got it now and it works great. Will have think about the pro version.
Thanks again
