Mick
Hi Fillip H.,
First off I wanted to say I know this is not your products error or bug, more of a can you help please post.
I installed the product Cerberus from VBulletin.org (vBulletin.org Forum - View Single Post - CERBERUS: 1 vB4: runs multiple domains with custom styles, forums, universal login).
But with DBSEO on it does not work, and with DBSEO off it works?
Something is stopping the URLS to appended from www. and satellite.
I have a really big satellite section that I believe should have its own sub domain (satellite.) and the only product that can give me this feature is the cerberus product).
Digitalworldz Satellite Forum
It does work, but the issue as I said is that it will not convert the www for the category to satellite.
I would also be more than willing to pay for your time on this if it was something you could help me with.
Cheers
Mick
DBSEO will rewrite all URLs to use the URL found in the AdminCP's "Forum URL" setting. DBSEO does URL rewriting and domain correction after all other hooks have ran, overwriting whatever that mod does.
To be honest I'm not entirely sure what could be done about this =/
Thanks Fillip H.,
I appreciate your input, I need to hire a coder to do this but I guess DBSEO is your product and if you do not think it is possible, I cannot see anyone else being able to accomplish it???
If the worst option is I need to remove DBSEO... is there a way that your product can redirect the SEO Urls back to the showthread.php URLS
Cheers
Mick
It's probably not impossible, I just don't know how specifically it would need to be done. It would involve file edits of DBSEO files, at least.
