Heloo I have a problem :(
jind
Your products are working for me 100% I'm very happy.
One thing I'm not working and it is View Forum Leaders.
I think, I write in support of vBulletin .... ok I wrote
They wrote that I had too much addons and they are bad !!
I had to do - Admin CP -> Maintenance -> Diagnostics -> Suspect File Versions ( LOL all product is OK)
Step 2
Next, disable all products (except vB Blog, vB CMS and Skimlinks if you have them.)
Step 2 does not lead to anything
NEXT
Then manually uncheck all plugins that are not for 'vBulletin Blog' and vBulletin CMS'
I even deleted everything but to no avail
Can you help me?
All modules are perfectly fine, but not the only thing it is to display leadership.
HELP ME.
FIXED!
It was enough to remove registered users from setting in
Display the list of groups.
Thank.
Glad it got sorted =) - Thanks for taking the time to report that and your solution, it'll be useful if anyone else has the same issue in future.
Regards,
Cosmic
