Mondy
'Hi all -
Page url Live Entrepreneur Chat - GBLCG.org should show the shoutbox under the the Announcement Module to Unregistered Guests. I believe I've set everything correctly in admincp to allow this to happen - but it doesn't seem to appear when I look at this page 'logged out' myself.
Any idea what this may be caused by?
Thanks heaps in advance -
Mondy
Are you running a guest cache system like Varnish on your server?
I cannot find a logical reason for why it's not showing up for guests on your forum. I tried replacing the template with a shell template to eliminate any vBShout settings, and that did not change anything.
Additionally, no HTML from the module shows up in the source.
I can only conclude that guests are being served a (very) stale version of the page.
Fillip H. -
Thanks for your rapid response - and, yes, I am stumped too.
Checked settings with my host and across my admincp and nothing seems to flag 'error'.
However, I suddenly realised that all was well before I upgraded to vB5 5.0.3.... Shoutbox was visible to guests as intended.
You haven't received any other comments about Shoutbox versus 5.0.3 recently by any chance for I am suspecting something may have changed with that latest version that causes this issue to appear.
Feel free to nose around my settings and files when/if needed - I've left the gate open for you.
Not sure whether it would be worthwhile to raise this issue at vbulletin.org as well... Obviously, this is about a module not appearing as should be the case. It's got something to do with 5.0.3 I sense...
Thanks again mate!
Mondy
Sorry - Just found solution...
The Usergroup 'Guests' must be given 'Manager' status in it's profile. This keeps the shoutbox visible to this usergroup. Further allowances/settings must be determined in the 'instance manager'.
At GBLCG.org Guests can now see the shoutbox but cannot participate in the chat: Live Entrepreneur Chat - GBLCG.org
Hope this helps..
That's not the right solution though.
Unfortunately I deleted the PM with the FTP account prematurely as I was cleaning out access details from my PM box for security reasons, could you resend me an FTP account?
