Bug Fix Repair Tables - Odd Overhead Size
Noticed this not to long ago, seems a bit much but under Repair / Optimize Tables I noticed this
credits_transaction
10.50 MB
17.47 MB
66.00 MB
Overhead is 66MBytes, is this normal?
how many rows do you have in your transaction table, and when was the last time you optimized? high answers to either (or both!) will cause that, and isnt an "issue" to fix.
Weird there are a few, must be sharing the same table
credits_transaction
10.50 MB
17.47 MB
66.00 MB
dbtech_vbarcade_data
16.0 KB
66.00 MB
dbtech_vbarcade_session
16.0 KB
66.00 MB
the tables maintain a decent index to keep it running fast. is this causing any issues aside from alarm? again, i cant "fix" this without sacrificing the lookup speed, which is more desirable.
You need to add one more catagory "Possible Issue" lol I would have selected that instead
Speed is desirable by far, but the alarm was how big is it going to get and how fast is it going to get there. My main concern was performance but your saying as is its better off, and I trust your word for it
Did you run the new index query from one of the more recent threads (last few months)? If not, then PM me and I can switch the indexes for you and should have some minor improvement in size.
Legacy vBCredits II Deluxe
