Bug Disabled vbActivity - Fatal error: Class 'VBACTIVITY' not found
janslu
I have disabled vbActivity on my forum (but didn't uninstall it) and since then vbAnswer gives me an error when users post a new topic:
Fatal error: Class 'VBACTIVITY' not found in forum/dbtech/vbanswers/includes/class_dm_problem.php on line 191
Can you look into this? At this moment I really don't want to totally disable Activity, and I cannot re-enable it, yet...
Fillip H.
Staff member
Owner
Developer
Are you sure you used the Product Manager to disable it, and you didn't just disable a few individual plugins?
janslu
Yes. I have disabled the product. I have retried it few seconds ago - re-enabling for a second and disabling it again. Same result - same error. I am also using vbOptimize.
Fillip H.
Staff member
Owner
Developer
janslu
Hi Fillip H.,
Couldn't make the ftp access this week and decided to uninstall the vbActivity product. This caused a breakdown on threadview. I nailed it down to DragonByte Tech: Postbit Tabs (Lite) v. 1.1.2. I found out that it still kept information on vbactivity content in tabs, but even removing these blocks didn't fix it. I have disabled postbit tabs as a product and everything works fine. One thing I didn't try is to remove the postbit tabs content and then clearing vboptimize cache. All in all you should look into integration issues - disabling vbactivity product seems not to change relations in other DB products. I don't know what's hooked to class_dm_problem, but postbit tabs error manifested with the same kind of error in postbit_complete hook.
As for vbactivity I've had to remove it because of a noticable impact on performance.
Fillip H.
Staff member
Owner
Developer
I'll definitely test this again, it's strange that vBAnswers would throw this error as there's explicit protection against this issue in the code that produced the error. I'll let you know when I have more information or if I need on-site access.
Thank you :)
Fillip H.
Staff member
Owner
Developer
I'm unable to replicate this issue.
Hi Fillip H.,
You would need to simply disable the View in the PBTabs AdminCP menu, that will solve it unless you have a serious caching issue on your forum :)
Fillip H.
Staff member
Owner
Developer
As this ticket has received no further replies, I'll close it. If you have any further issues or questions, please feel free to start a new support ticket. Thanks!
vBAnswers
