Mv.c9
I installed everything correctly according to the readme.
1. Upload all files from the "upload" folder to your forums directory.
2. CHMOD the following folders to 0777
/dbtech/thanks/vbactivity_type
3. Import the product-dbtech_thanks.xml file from the "XML" folder at AdminCP ->
Plugins & Products -> Manage Products -> Add/Import Product
4. Configure your Usergroup settings by clicking "Manage Buttons" under
"DBTech - Post Thanks" in your AdminCP navigation menu, then
editing each button and setting your usergroup permissions from there.
the blue is that i done, the red i haven't. cause i cant see it in AdminCP. any idea ?
any help would appreciated.
Try giving your account either the Super Administrator permission or Can Administer Thanks :)
Btw, if you find your posters showing up as guests then run the following script:
/admincp/thanks.php?do=finalise&version=110
Ignore any errors you find at the end of the script run. If it does error, manually run
/admincp/thanks.php?do=finalise&version=111
I've been unable to find a specific cause for that issue, so I'm just pre-empting in case you have the problem :)
well, im not seeing that in the usergroup permissions.
Sorry I should have specified, it's in the "Administrator Permissions" interface - which you need to be logged in as a Super Administrator to see and access :)
