Amaury
I originally asked this on your guys' vBulletin thread, but I am moving it here after being told I could receive better support here. :)
The first one was already answered, but I'm including it just for convenience's sake.
http://www.vbulletin.org/forum/showpost.php?p=2422786&postcount=364
Amaury on vBulletin.org - 5/17/2013 at 7:01 PM Pacific said:
Any way to increase the columns' width or move things over so long usernames are on one line?
http://i101.photobucket.com/albums/m62/AmauryGarcia/Columns_zps4c2ee776.png
Also, I noticed there were no header and body backgrounds on Username History like under the About Me tab. Was that intentional; if so, any way to add them? I tried once with custom CSS, but it made things look weird.
http://i101.photobucket.com/albums/m62/AmauryGarcia/Background_zps353a633a.png
http://www.vbulletin.org/forum/showpost.php?p=2426285&postcount=371
Amaury on vBulletin.org - 6/6/2013 at 8:36 PM Pacific said:
Just checking to see if you might have overseen this. I posted it on May 17.
http://www.vbulletin.org/forum/showpost.php?p=2427475&postcount=374
DragonByte Tech on vBulletin.org - 6/11/2013 at 2:22 PM Pacific said:
I don't know what you mean by the second half of your post, but you can alter the width of the columns by editing the dbtech_username_change_member_block template.
To be certain posts aren't missed, you should post in our support forums
vB.org threads are much, much harder to keep up with than threads on our own forum (as each question is its own thread)
Fillip
Can you be more specific as to what you mean by the header and body backgrounds?
These screenshots should explain:
For the second screenshot, notice how it's not like the first? The header background would be where Old Username, New Username, etc. are, and the content background would be where each change listing is.
In profile customization, the areas are controlled by Header Background and Content Background, respectively, Or, if you customize your profiles with style variables like I do, Header Background is controlled by postbit_header_background and Content Background is controlled by postbit_lite_background.
Basically, I want to add backgrounds there for the header and content that would be controlled by those style variables. I know it can be done with custom CSS if you use {vb:stylevar postbit_background} (example), but the last time I tried, it messed with other areas of the site.
I've prepared v1.2.3 with the necessary changes for release tonight - this will also be an issue in all our other mods that use profile tabs but it takes way more time than I have available to fix it in all those mods.
Thank you. Looking forward to it.
The biggest issue is that if someone uses a custom background image, depending on what it is, the name changes list could potentially be hard to see.
Anyway, this and Post Templates are the only modifications we currently use from you, so you only being able to get this on Username Change for now is fine with me. :)
Just wondering if something came up that night and you were unable to release it? I'm still seeing the last update date as April 5 on the vBulletin.org thread. :)
(I also fixed a typo in post three.)
I must have forgotten to update vBulletin.org - the best place to get our addons is always this site anyway :)
You've also forgotten to update the change log in the OP the last few times on the vBulletin.org thread. Last one in there is 1.2.0. Bad Fillip H.! :3
But in all seriousness, thanks! :)
5K
4K
Legacy Username Change
