max1982
Hi
I just got a small problem with the advanced thanks plugin after updating the plugin the buttons on the forum disappeared and cannot seem to get them back on, i have checked the settings in the Cpanel and seems all ok, can some one let me know what could it be and if there is a fix for it.
Regards
Wafic
I didn't edit any template only updated the vbulletin to 4.2.1 and then updated the template and then updated the plugin. if i remove the plugin will i loos the thank and dislike counts? i have checked the templates there are revert for the old one i used to use but i don't use it any more i tried the original template from vbulletin also they are not there.
Update: I've replicated the permissions set up in your screenshot and I can confirm that the buttons now display for me in a post I looked at :)
Let me know if there are any further problems :)
I also am having trouble getting buttons to show except they havent shown at all, the post thanks/likes stats shows in the postbit userinfo but no buttons, i have selected all permissions and still a no go.
any help would be great,thanx
