stig
  • Alternate Coloured Lines - Not Working - All the same colour
  • Users unable to over-ride Icons setting - goes to a blank page after change (profile.php) and nothing appears to be changed
  • Changing font size makes no difference at all
  • Some users unable to post in second instance, although posts are recorded in the log
  • No option in forums manager to turn notifications on and off
  • "No Auto Idle" option does not work
I've updated to latest VB, upgraded VBShout several times (no errors seen).
Here's a little more info...
WRT shouts not appearing in the second instance..
If I use the "Hide Avatars" over-ride, I don't get shouts in the FIRST instance either..
And the "Hide Avatars" option is working for other users..
Could you please PM me with FTP info and AdminCP info and I will look into this for you :)
Sorry Fillip,
Before I saw your post I reverted to an older version, had problems, uninstalled, installed fresh..
Now I'm getting the infernal "loading..."
In the Error console in Firefox I get :$.proxy is not a function:
When I click on that I get :
// Initial shouts fetcing
this.get = setInterval($.proxy(this, 'timer'), 1000);
Any suggestions please?
That has been fixed in v5.4.1, though you might as well wait because 5.4.2 will be available within a minute :)
Please try flushing any cache systems or reverting any templates.
The code no longer exists as of 5.4.1 so it's not possible that it's still giving the same error :p
you're absolutely right.. my copy-over failed it seems..
All seems OK now, thank you very much :)
I have to go out, will play some more later..
Cheers,
Dave
OK.. I'm back :)
Couple more things I've noticed..
When I try to add a new chatroom, it fails and gives : A required field called creator is missing or has an invalid value.
And where do I select forums for notifications? I'm not seeing anything in the forum manager.
The "Enable Active Users Block" option does nothing in a second instance.
Edit : The Font Size dropdown appears to do nothing in IE(8) ..
And here's a good one :)
Edit : In all instances, when you hit "Save" on the top set of options (About the permissions area) it clears out ALL permissions, and you have to re-edit them again.
Edit: When users in the first instance hit a "Post" event (IE 50 posts), they get a brief glimpse of the second instance - in my case a moderators private box..
Cheers,
Dave
Been fixed in the latest hotfix :)
The "Notifications" link in the AdminCP.
I've uploaded another hotfix for that :)
With the browser mode set to IE9 Standards it works fine. Unfortunately I've been unable to fix it for lower versions of IE :(
Only if you're running Suhosin, and that is because they are separate forms :)
I've unfortunately been unable to verify this, so there's nothing I can do about it :(
Closing this because it's becoming unmanageable with 10+ issues in one thread :p
