twolegit
hopefully these are easy questions but i need to ask
1. is there a download log which tells you what member downloaded what?
2. is there a way to set the download limit to say 1 download every 5 days?
the mod is great btw!
There is nothing in there now to log what a user downloaded. If you add it as a feature request I can add it with the next update.
The only limit right now is through usergroups that allows you to set the amount of downloads and download size per day.
I will put both in the feature request! thanks for the fast response! great product...
oh...where would i find the feature request spot....so i looked and couldn't find it
Just open a thread in the correct support forum and it will have a "feature request" thread type option =)
Legacy vBDownloads
