Hi,
i change today from vbseo to dbseo with import but i get a error with too mandy redirects in every posting or thread.
i change my .htaccess from
to this
I did change it back again to vbseo but i hope you can help me.
Is it possible too that we can set "Relevancy Replacement"?
thanks for your help
best wishes
Sid
# Comment the following line (add '#' at the beginning)
# to disable mod_rewrite functions.
# Please note: you still need to disable the hack in
# the vBSEO control panel to stop url rewrites.
RewriteEngine On
# Some servers require the Rewritebase directive to be
# enabled (remove '#' at the beginning to activate)
# Please note: when enabled, you must include the path
# to your root vB folder (i.e. RewriteBase /forums/)
RewriteBase /
RewriteCond %{HTTP_HOST} !^www\.simsforum\.de
RewriteRule (.*) http://www.simsforum.de/$1 [L,R=301]
RewriteRule ^((urllist|sitemap_).*\.(xml|txt)(\.gz)?)$ vbseo_sitemap/vbseo_getsitemap.php?sitemap=$1 [L]
RewriteCond %{REQUEST_URI} !(admincp/|modcp/|cron|vbseo_sitemap|mantis|phpMyAdmin|admincp)
RewriteRule ^((archive/)?(.*\.php(/.*)?))$ vbseo.php [L,QSA]
RewriteCond %{REQUEST_FILENAME} !/(admincp|modcp|clientscript|cpstyles|images|mantis)/
RewriteRule ^(.+)$ vbseo.php [L,QSA]
#RewriteCond %{HTTP_HOST} !^www.simsforum.de$ [NC]
#RewriteRule ^(.*)$ http://www.simsforum.de/$1 [R=301,L]
to this
RewriteEngine On
RewriteBase /
RewriteCond %{REQUEST_URI} !(admincp/|modcp/|cron|dbseo_sitemap|mantis|phpMyAdmin|admincp)
best wishes
Sid
