hey
I have a serious problem with thank/like...
dislike is disabled but thank/like runs and you can thank/like at the same time..
BUT
most of my users cant...
some of them can thank/like in a post
some can only thank
some can only like
some cant do anything...
its all over the forum ... and yes its a custom skin - but nothing besides the stlevars has been changed
Please advise
and in some posts theres no thank/like box below at all
my users are quite confused...
i have had all my users chip in... unfortunately in danish so i cant just point you to the thread..
but it seems that they can only like admin posts
admins (i) cannot see most of my likes ... its different
the rest i kinda random it would seem... certain users have no functionality below their posts - but a few posts later it shows up when they write another
In your question you stated that the issue does not happen on the default skin. If that's the case, then we're unfortunately unable to assist.
1. Please ensure you have set up the Usergroup Permissions properly. Most of your issues could stem from that.
2. If you are not running vBActivity, please consider upgrading to v1.1.1 BETA. While it does have the BETA tag - with the exception of vBActivity integration - it works, and shouldn't be plagued by the issues described here (though neither should 1.0.1 =p)
3. It's possible that some posts has thanks or likes turned off. There's a form to do so when posting via the "Go Advanced" editor.
i do not run vb activity and i have checked the settings... all check out
so i re-checked the posts... its no. 3
i have 2 posts not 5 min apart by same user inthe same thread - one have both engaged and one have both disengaged... she has not done anytjing different in those two posts..
and it is BOTH in default skin and my custom - no change!
i obviously makes something quite random... for instance all thanks are disabled from admins - but settings have dem on... none of my admins have touched the settings..
how is that even possible
and just a note :)
no users - nor admins have permissions to diable thanks/like in posts - so they havent done anything :)
Try upgrading to the Beta then, v1.0.x has some issues with thanks and such getting disabled.
Once you do, you'll need to re-configure your usergroup permissions, and they will have moved to a new screen; Button Management -> Edit (for each button).
If that does not help anything, please PM me with FTP information and an Admin account, and I'll look into it :)
PS: Please don't double or triple post, we'll reply as soon as we've read the post, so please always use the edit button unless we have replied :)
