Question Problem with own currency
gewar
Hey,
First I'd like to say this mod looks great.
I'm having a problem though. I want to use it with my own currency as we have an online game.
The database table is 'war_user_resources'. The row in that table that has the userid's is simply called 'userid'. And the currency row is 'geos'.
However if I enter 'war_user_resources' in the points table inside the settings, and 'geos' in the points field, it always shows 0 inside vbshop.
Any ideas?
Thanks,
Luke
I believe it requires the points field to be available in $vbulletin->userinfo though I'm not sure.
I'll look into it :)
Thanks a lot.
But before in points table, it said 'user'. Which would point to the userfield in the database. However is that the case, it should also work if I change it, right? As my pointsystem is not in the userfield(and can't be there codewise for me).
Nowhere can I fill in the userid field, so I assumed it automatically checks for the row 'userid'. But then again if you have a pointsystem that doesn't work with a row exactly named 'userid', then it wouldn't work.
Sorry, I've been massively preoccupied in the past couple of days - I'm currently in the process of moving not only house, but country altogether.
I'll look into it ASAP, please bear with me until I have more info to give you :)
No problem. Didn't know you were alone on this :). Thought perhaps another user might've encoutered a similar problem in the past, with a possible solution or not.
Good luck on moving!
I read you were working on a new version. Do you think this thread has a chance of being adressed in the new version?
Legacy vBShop
