ftagods
i get this msg after my logo :
Warning: unserialize() expects parameter 1 to be string, array given in [path]/index.php(594) : eval()'d code on line 14
how can i fix this?
Hi there,
What version of vBulletin are you running exactly, and is index.php leading to your forum or the cms? :)
Seems like the forumhome_complete hook is causing the issue, if you disable the option "vB Optimise: Display Total Saved Resources" in vB Optimise settings, does the problem go away? :)
no i still get same msg . if you got msn messenger please add me is faster xxxxxxxxxx
