Chase
PLEASE HELP ME!
Just upgraded to vbcredits 2 and vbshop... tried to set 'credits' in the points setting.
Replaced 'user' with credits
and 'dbtech_vbshop_points' with credits
I get a database error now
please please help me! How can I fix this
Please undo that specific change.
If you cannot access your AdminCP, please add the following to config.php
phew thank you so much! I was panicking big time!
What I was trying to do was link vbcredits' points into vbshop. How do I do that? My credits table in vbcredits should be called credits
Nah the table is user and the column is credits :)
Don't forget to comment out that define() when you've corrected the option, otherwise no mod will load :p
Thank you so much for the help guys!
I have deleted that define string from my config, changed dbtech_vbshop_points to credits and it works fine.
Legacy vBShop
