Grumpy
I have created an additional instance [Invite Instance] and added two fields [first and last name] and removed human verification for this instance.
I have created two criterias one default and one for invite instances.
When a non-invited member tries to register after having email verified they see the default register page with human verification [this is all correct] but when they fill out form and click complete they get a return error that the first and last name fields were not filled out. This is incorrect because the first and last name fields are to be shown only in the invite instance.
The opposite occurs when an invited guest registers. They see the invite register page with the first and last name fields and no human verification [this is all correct] but when they fill out the form and click complete they get an return error that the human verification was not completed. This is incorrect because that is only suppose to show on the default registration page.
Is this a bug, a pro feature or am I doing something wrong?
I'm running 4.2.2 PL2 and v2.0.5pl2 on a bare bones test site so there are no mods to interfere.
Any help would be greatly appreciated.
Thanks in advance.
Update with newer info
I originally started out setting this up for a dual purpose registration page for non-invited and invited guests when I ran into this problem mentioned above.
I decided to completely uninstall and delete folders from server and start fresh. When I did this I made only one change from stock setup, I unchecked human verification and tried to register with no luck. I had a return error after clicking complete registration saying "The solution of task you submitted was incorrect. Please read the instruction and try again." This is the same issue I had originally after adding two new fields to use with customize registration page mention also above.
Apparently there is a table that needs fixing because the way it is I cant manage the instances fields to customize a registration page without getting errors.
You cannot mark any fields as required in vB's "User Profile Fields" manager if they are not displayed in all instances.
The same goes for the Human Verification solution, if it's required then it needs to be displayed in all instances. AdvReg can't override this requirement, unfortunately :(
Thank you for the explanation on how it works. :)
Quick question is there a way you can implement this when using the referral and sending an invite that the members user name will automatically show in the referral box? (i.e. when you send a link for someone to join and you get credit for them joining http://www.mysite.org/forum/forum.php?referrerid=1)
If so I'll start a thread on future adds to this mod.
Thanks...
I believe vBulletin does that on its own, at least it's always done that for me.
When I do a test invite the referral or the email address is filled out automatically in the custom page. My understanding this was suppose to be the way the mod works [at least on the email address] to help cut down on registration time.
Sorry, I'm confused. I meant that if I click on a link with a referral ID, when the registration form loads vBulletin will pre-fill the username of the person whose referral ID link I clicked.
That is a vBulletin feature, not exclusive to this mod.
Legacy Advanced Registration
