Question How get image on right place
bosss
will attach image to better explain...what i must do to get image "in" slider and see border (header) with name of slider like another blocks
mean how put image some "down" - image is 730x255
use latest version of slider
regards
bosss
The slider is not meant to have a header. To do what you are wanting, you will have to customize the CSS files.
Brad
via Moto X
I do not want header - just that look that image is inside block ...you see that black "line" back image...
regards
bosss
Right. You still need to modify the CSS to make the top border of the slider thicker, and therefore the image area smaller.
Brad
via Moto X
You should contact your skin developer for assistance with this, as we are unable to give you specific instructions for modifying vBSlider to look different in that way.
Thanks for reply. Should not fix be in dbtech_slider.css?
never mind ...will try contact skiner.
regards
bosss
Legacy vBSlider
