unit1stealth
Had a question. I'm running a status plugin that was created by DragonByte... and I'm wondering if you guys could tell me how to customize the forum block, of this status plugin, to where it would show more than the last 5 statuses. And rather 10.. or 12, etc.
Would appreciate any help.
Regards,
STEALTH
Hi there,
Your site is actually showing up on our piracy tracker as having Pro files for vBActivity & Awards on your server - we checked manually and there are indeed unlicensed pro files for vBActivity & Awards on your server.
Unfortunately we won't be able to give you help or support until those files are removed :(
Regards,
Hi there,
Regards,
Are you 100% sure? If I remember correctly, I got all my plugins off vbulletin.org. Including vBActivity.
