Colour Issue
JoN
I just installed the mod....works great :)
but there is a small isue with the background colour..
How can i change it?
Thanks in advance
Thanks in advance
It uses the color from the skin you are using. So to change it would require you to make a custom css class I think, right now I think it uses "postdetails" as the div wrapper but im not 100% sure, its all in the template "dbtech_thanks_postbit_entries"
This is most commonly the result of CSS settings, namely the background attribute of the .postbitlegacy .postfoot .textcontrols a, .postbit .postfoot .textcontrols a, .eventbit .eventfoot .eventcontrols a { CSS class, in postbit.css.
To fix it, please try the following steps:
Step 1) Remove all the contents of the postbit_control_background StyleVar.
Step 2) If that didn't fix it, please enter the postbit.css file and find the .postbitlegacy .postfoot .textcontrols a, .postbit .postfoot .textcontrols a, .eventbit .eventfoot .eventcontrols a { CSS class, and remove the background: definition.
Hope that helps :)
