Bug Wonky sublinks using vBadvanced
SouthernGirl
Everything was working fine with my vBadvanced CMPS including all tabs and sublinks highlighting as they should until...I moved everything in my "forum" folder into the httpdocs folder so that I didn't have the extra "forum" word in front of everything in my url's.
After that, everything was still fine except...when I click on the tab in the navigation bar for a CMPS page it highlights as it should. But if there is any sublinks for it and you click on one of them it highlights the "Home" tab instead of the tab the sublink is for as it should and did before I moved the files.
So, I need to know what I need to do now to make it highlight the correct tab when sublinks are clicked on? I think it is probably a setting somewhere but I don't know which one or where.
I asked about this on vBadvanced forums and this is what they said...
Right,you have to be able to add a Tab ID to the link, because all the pages with CMPS have the same THIS_SCRIPT. I have not used DragonByte's plugin so I do not know if it can or not, but the one I linked above can. Have you asked about this on DragonByte's forums?
Any help is appreciated...thanks.
If you pm me a admin account I can look into it for you, and see what may be causing the issue.
Legacy vBNavTabs
