Bug VBsignatures not displaying
Website
http://equestriaforever.com/
Product version
1.1.0
Forum version
vBulletin 4.2.x
xEnde
So I recently did a full install of VBsignatures, everything went well, but when I enable it in the adminCP it does not display on my forums.
All of the files are on the server.
We are not running VBseo
I have the plugin enabled.
I have it enabled to make a new tab, and display in quick links and community links.
My user group has permissions.
Belazor
Staff member
Owner
Developer
Can you enter the Navigation Manager and ensure there are navigation entries for vBSignatures there?
If not, please try re-importing the XML file.
If it still doesn't work, please open the XML file and ensure there's <navigation> entries in there.
If not, please try re-downloading the mod from here and re-uploading and re-importing the XML file.
xEnde
It displays in the navigation manger, when I clicked edit, it looks like this:
Screenshot by Lightshot
I did a re-installation and still had the same results.
Belazor
Staff member
Owner
Developer
Have you checked the Usergroup Manager for the permissions from this mod as well? I know you said usergroup has permission in the OP, but I wasn't sure if you're referring to the UG permissions found in the nav manager or the actual UG Manager.
xEnde
Ahh thank you, that fixed it!
vBSignatures
