Sarab
Thank you for your great work in this mod =)
My problems are because my site is Arabic, therefore I have 2 problem:
1- the Item cart being in right making the skin ugly, screenshot:
http://www.phantom-downloads.com/memspace/images_up/2bf821bc75c6a31aecf4632ba0e5bbd9.png
Look the cart being in the middle +.+
and notice the numbers 1 2 3
It should be arranged 2 1 3
So can you help me do this arrange?
2- their is some places don't support Arabic words like here:
http://www.phantom-downloads.com/memspace/images_up/7abac843dba4d17da56d77daab56c278.png
see in the pop up for the details the Arabic language became codes ="(
How can I fix that?
Best Regards,
Sarab
1. Change CSS in dbtech_vbshop.css
2. That has been fixed in the latest version, unless your skin runs on some other character encoding other than UTF-8 or the default ISO :)
Thank you for your help =)
1- it worked but their is a little problem here:
http://www.phantom-theater.com/memspace/images_up/12b63b0b298f9af50452288f9f2dedf1.png
I want to be some space between the cart and the main block, can you tell me what to do?
2- I download the mods yesterday the latest one, and my database charset is " latin1_swedish_ci " , and I try to see the shop in the default skin, and the problem still their, so how can I fix it?
Best Regards,
Sarab
1. I don't know that, play around with the padding in the CSS or something.
2. Please post the charset your language is running at (Language Manager in the AdminCP) and also the wording of the phrases used in the hover (the "Yes" "No" and "Unlimited" phrases).
Thank you =)
1- I will try then ^,^
2- the charset is " ISO-8859-1 ", about this :
where I find it?
I've tested this on my local board, vBulletin 4.1.4 with an ISO-8859-1 language and the same text that is having problems for you. I've been unable to replicate this issue, so sadly it's not something I'm able to fix :(
I see ="(
Then can it be fixed in next update or I will be in my own for now +.+?
Thank you for you time & help ^^
Best Regards,
Sarab
I see +.+
Then I will try some magic in it until it work XD
Thank you for your help and support ^^
Best Regards,
Sarab
Legacy vBShop
