jgruberman
I have the shoutbox installed and every time I post to it, it doesn't show in the box, but if I click on Archive, it will show in the archive as if it's been logged, just not displayed. Any thoughts to get them to show in the box? Feel free to see for yourself on DFWSportbikes.org
Try re-downloading the mod, re-uploading the files and re-import the templates. Also ensure that you've reverted any customised templates :)
Did that.... now not showing up at all, even though it says it should in the Instance Management? I must be missing something...
Are you running any form of weird compression or cache software on your server?
The following errors are showing up in the error console - they are the reason, but the cause is your server:
Uncaught SyntaxError: Unexpected identifier in http://www.dfwsportbikes.org/dbtech/vbshout/clientscript/jquery.tmpl.min.js
Refused to display document because display forbidden by X-Frame-Options.
Nope - would you like a temp admin account to look into the forum yourself? I can't figure out what's going on with it.
The Shoutbox was working on your site when I went to check it - all the errors I posted above are gone. Can you please double-check on your end?
If I change it to DISABLED and put the code for the instance in the navbar template, it works fine... as just hoping to select "Below Navbar" and it work just the same - guess not. Works now though with my workaround :)
