Bug Posts labeled as Attachment on Leaderboard
Loony BoB
Something very minor indeed. :) For now I'll jus tell my members it's because posting shows how attached they are to the forums. ;)
No, that's not what's happening. What's actually happening is that the Points for Attachments points type is not editable in the settings, whereas it's displayed in the front-end.
There are a few issues with the default configuration. Correcting them requires an update, though you can manually correct it by running the following queries, then clicking Repair Cache.
UPDATE vb_dbtech_vbactivity_type SET display = '5', settings = '20' WHERE typename = 'totalpoints'
UPDATE vb_dbtech_vbactivity_type SET settings = '16' WHERE typename = 'activitylevel'
UPDATE vb_dbtech_vbactivity_type SET settings = '15' WHERE typename = 'attachments'
UPDATE vb_dbtech_vbactivity_type SET settings = '0' WHERE typename IN('albumpictures', 'attachmentviews', 'ttbattledraw', 'ttbattlewon', 'ttbattlelost', 'tttournywon', 'tttrade')
(Remember to change your table prefix from vb_ to whatever you use)
Legacy vBActivity & Awards
