allan84
in my gallery I have two albums:
public and my album
If I upload a image all work fine except they are stored in My Inactive Images everytimes, I don't know how moved them in public folder and why this happens
thx
If it's put into inactive images, that just means all the details didn't get filled out. This happens sometimes if you upload a lot of images at once and the server can't keep up with the ajax requests.
You can make them active by editing them and setting them to active :)
When I send an image I had not checked the downloadable box, it should be marked by default I thinh, but in the directory inactivate, I do not see how I can edit the images to return them active, I don't see the pencil, thank you
What about if you change the ACP Gallery General Options settings from New Style to vB Style, do you see the option to edit the image there?
exact! if vb newstyle is "on" I , I can't modify picture, if vb3 is "on" all work fine, a bug??
thank you for your help
solved
Legacy DragonByte Gallery
