First I'll give you the canned response for how to put vBShout in a custom location:
To put vBShout in a custom location, do the following:
Step 1: AdminCP -> DBTech - vBShout-> Instance Management -> [Edit].
Step 2: Change the Auto-Display Shoutbox setting to Disabled.
Step 3: Write down the the Varname setting. For the default shoutbox, it's instance1. The rest of this guide will assume you replace instance1 with the actual Varname if it is different.
Step 4: Enter the Style Manager and add either {vb:raw show.vbshout_instance1} (vB4) or {$show[vbshout_instance1]} (vB3) to the templates you wish the shoutbox to appear in.
For step 4, add it to FORUMDISPLAY.
Then, to make it display only in your admin forum, wrap the code from Step 4 in:
<vb:if condition="$foruminfo['forumid'] == x">
</vb:if>
