Question How do I remove the: Mentioned: and Tagged: Display
Void
Hello, Fillip H.
I was wondering how do I remove the Mentioned: and Tagged: options from below the user names. I did not see an option for this and was wondering what piece of code I need to remove to get rid of these, let me know. I also have some other boxes under the usernames that I would like to remove (I know this doesnt relate to the mention and tagging) but, I was wondering if those will be removed the same way?
Thank you,
Void
The Pro version lets you control individual postbit entries, but in the Lite version you can turn on the Manual Postbit Deployment setting in order to remove it entirely.
Hmm.. Well I tried unistalling the product yet this still shows up under the user name:
If you're using a custom template that you manually inserted the postbit into, that could be why.
Nvm, I fixed it by turning off on manual post bit deployment. I also just relized this was caused due to the user tagging not user thanks/likes, sorry about that :/
Legacy Advanced User Tagging
