Bug Folder Controls Block Will Not Move Unless Download Is Selected
CharlieDelta
The Folder Controls block will only move to the top when the Move Download Options is set the "Yes".
With the Move Download Options set to "No" and the "Move Folder Controls" set to "Yes" the folder control stay at the bottom of page.
Yes, you are correct. I wonder how that went unnoticed. I'll look into why it don't want to play nice. :p
OK, I do believe I got it fixed. Re download the product and upload, dbtech/vbsuper_pm/hooks/preview/template_render_output.php
Where in the heck were you during beta testing. :p
You can re download the product and re import the XML, no need to upload any files.
It is when you are viewing you messages, the list, not a individual pm.
ok i see yes that dont work i guess ..well i guess i didnt catch this cause i had them both set to yes and this was on top and it didnt look off to me i never upgraded to latest yet either will do that soon
Legacy vBSuper PM's
