Question Excluded From Sending PM issue
Steris56
ok my issue is when i set this to no Excluded From Sending PM's Active then i select the usergroups excluded i have allow to reply to staff to yes
then i select my staff in which they can pm
what happens then is this seems not to work i can still pm everyone even though i am in excluded usergroup
what i want to achieve is my new members i want them to pm staff i select and that is it
am i doing something wrong or missing something
Sorry, I don't understand what you're reporting. Can you please screenshot the options you're referring to and your configuration, so I can replicate it in my local environment? Thanks :)
now when i select the first option to no instead of to yes so that the usergroups can still pm but pm to admins for example it dont work cause when i tested it out with a test user as a new member i was able to pm other members so my question is am i doing something wrong or missing something
just to clarify what i want to achieve with this is if i was a new member i can only pm admin for example and not any other user group
Sorry, I have not had time to look into this further. I will keep this thread open and get back to you as soon as I have a solution or if I need more information.
Legacy vBSuper PM's
