webrunner
I have set up vbmail exactly as suggested in the documentation but the bounced mails are not fetched.
When i use webmail to look inside the emailbox there are 274 bounce mails, but none of them show up in vbmail.
What could be the problem?
What happens if you run the Fetch Bounced Mail (or whatever it's called) Scheduled Task manually? If there are any issues connecting to your server, it should show up there.
Could you try adding
ini_set('display_errors', true);
directly beneath <?php in config.php
That means there's an error on that page that your server is hiding, otherwise the word "Done" would have been printed on a grey BG :)
You will need to restart Apache or whatever other service you use for sites in order for changes to take effect :)
I first reloaded the configfile but that wasn't enough. It is now running and fetching mails :)
Thanks for your support..
Legacy vBMail
