Question Baner resize
Website
http://vbtest2.autogas.co.rs/forumads.php
Product version
1.0.1
Forum version
vBulletin 4.2.x
Dora
If there is no defined package, there is no option cofigure ...
When a defined package, configure is located just on the package tab, bottom right not to be seen.
Showing my placeholder image size banners, and the true picture is a small thumbnail.
Example 1:
Example 2:
Banner is 697 x 625, 697 x 625 placeholdder and dimension to place banner is 800 x 100
Dora
differently...
1. The dimensions of the image are 687 x 625
2. Baner space set
Dimensions
Choose the dimensions of this banner space, width x height (in pixels). px x px...
is set to 500 X 250
3. The final result is like the image below, outlines of the image are like the final image 687 x 625, the image (Below Navbar) is about 200 x 200.
Resize is not working good, or the user should know to make a baner of exact dimensions?
Next question or suggestion...
If there is not made any package for sale than, there is no way for the user to add an image, there is no configure button.
If there is made a package tab, the configure button is only on that tab, wheh the user click on the package tab.
The configure button can not be seen right away so it makes a confusion to the user just like the thing that he must make a exact dimension of the baner.
Belazor
Staff member
Owner
Developer
Yes, the user must upload banner images of the exact dimensions in order for them to work properly.
Dora
Thanks for your reply ..
And the second question?
DragonByte Forum Ads [Hostboard]
